Another gauge to add to my truck...
CSIPSD
Bend, OR
Here is one before the Quad A pillar...
The HPOP gauge is still a few weeks out.
fordtrucker4life!
I work with waste
SE Michigan
where in the world do you have a space to put this one joe? :eek:
gonna look like a peterbilt dash in your truck before long. :sweet
I got in a KW T800 that had probably 15 gauges. Looks awsome when they are all lit up. There was boost, pyro, trans temp, front axel temp, rear axel temp, oil temp, oil pressure, coolant temp, primary air psi, secondary psi, air psi applied to the brakes, volt gauge, fuel level, tach, and speedometer. :eek: There can never be enough gauges. :sweet
CSIPSD
Bend, OR
High pressure oil Pressure. You 6.0 guys dont seem to have as much issue with it but the 7.3 it is a big issue with Higher HP programs and injectors
platinum01
Willis, TX
Joe you are the man.:sweet :sweet Were do you find all of these different gauges? I have been all over online and can't find any other then the 3 basic. The wife likes the ones I have but I need more. Looks good can't wait to see when this one gets installed. :thumbs :thumbs :thumbs
