anybody try this?
lower 48 shipping....sheesh theyre in GEORGIA !
and hey....
we do not charge a "handling" fee and still don't
understand why companies do.
The CX-1 is custom built when your order is received and it may take up to 2 weeks to get your unit built and shipped.
We will keep you informed and let you know if we ship earlier. Also, we will call you with a tracking number the day your
unit is shipped.
550roofer
vancouver, bc
CX-1 seems like a good system. The other way to make diesel, like what i think most people do, uses something to heat the oil, and u add some kind of alcohal as well as a filter. The alcohal is what makes biodiesel at the pump not compatible with some engines. (only OLD engines)
Alcohal is a solvent and eats plastic. Newer vehicles don't need to worry but older ones might have a problem with the lines that carry fuel. They are eaten from the inside out. At least thats is what i've heard.
Why do they add alcohal u ask? To increase the BTU's
bbressler
Happy, TX
I don't think your statement is quite right....
Biodiesel, when made properly, should contain NO ALCOHOL. It is used as part of a chemical reaction, and during the process, most of it settles out with the glyercin. Any other traces should be removed when the fuel is washed.
This CX-1 is snake oil. I wouldn't buy it.
dserge66
