Bad Fuel Leak
02Oilburner
SDD Power Hungry
Raleigh, NC
Hello all! I hope everyone is doing well. I have a pretty bad fuel leak I need to address ASAP. Where are the possible leak areas I should be looking at. I have the Riffraff Fuel cross-over kit in the box ready to install. I want to fix the leak and install kit at the same time. I am waiting until the truck cools of to go check for leaks.
02Oilburner
SDD Power Hungry
Raleigh, NC
I went and checked the truck for leaks and the drain switch is leaking like a stuck pig. I just ordered the #12-001 Fluorosilicone Drain Valve O-ring Set from Dieselorings.com. Ill let you know if this fixes the leak totally.
;tu Glad you got it fixed.
As you install the cross-over kit lines ? A little hint ? TIGHTER IS NOT BETTER.. when it comes to O ring fittings ?
Finger tight.. then Snug, with a wrench. check for leaks.. then recheck after a couple'a Op temp~cool downs.
:dunno
