Banks 6 gun or Hypermax 3 for 7.3L?
HondaCowboy82
Newbern, TN
Banks 6 gun or Hypertech III for 7.3L?
ive got a 2001 Ford F250 4x4 with the 7.3L (hooah!!) and the 6 speed manual. have a 4 inch straight pipe and S&B intake. which would produce more power for me ... the hypertech III or the Banks 6 gun (up to 62hp + 163ft/lbs)?
keanoknick
Big Stroker
Cowtown TEXAS
I'm not sure which one of those is better, but if power is what you're looking for, you need to forget those, and call Tony, and www.totaldieselperformance.com and have him set you up with some custom tunes. He will customize them for YOUR truck, and to what YOU want, power, economy, towing, smoke, etc.....
sagebel
Stock? Pfft!
Albuquerque, NM
I would take the Hypertech over the Banks. More value for the dollar. However, I run a DP Tuner chip and many others have a good luck (and power) with TS Performance and Tony Wildman. An off the shelf chip/box cannot match something from the custom tuners. All here will recomend a set of guages as well. You will only need two guages (Exhaust Gas Temp and Boost) with the manual trans.
Scott
