banks brake
jlaursen
Boise, ID
Having an issue with my banks brake system , It should activate between 15 and 45 mph and foot off the throttle, but it activates when accelerating and just after 45mph. Not less than 45mph? any ideas?
Talked to the Banks people and they had not heard of this issue. Was told to check the throttle position sensor and the speed sensor. Found the throttle sensor and it seems to be okay, now need to find the speed sensor and verify performance.
I think it needs a new Banks controller but what do I know?
I am hoping someone has heard of this issue so I can reconnect the power to the vacuum pump for the brake system, as it helps in the hills of Idaho.
roosterdiesel
Earl needs B100
Amarillo,TX
I'm with you on the new controller, but have no experience with the product. I'd call Banks back and ask them what input values would cause the operation you are experiencing. It has worked properly right?
The vehicle speed sensor is on top of the rear differential.
Welcome to SDD!
