comment Battery Terminal wrench choice?
What ya'll use to remove the battery terminal clamps on your SuperDuty-Excursions batteries? I know some use a small 5/16 wrench,others use a crescent and some a pair of plyers:D
I been using a GM battery terminal wrench for ours trucks probably for the last 9 years,yes a GM tool. Easy off and easy on! I recommend it :sweet
TampaDieselFX4
Funny Farm
Never use pliers or adjt wrenches. I use 6 point sockets or wrench noted above. I believe we use 8mm, not the 5/16" GM uses. You want to check with a socket before you buy that gimic.
I'm not sure when if the terminal nut sizes changed after the run of the 7.3 or what year of the 6.0.
bbressler
Happy, TX
I found a ratcheting wrench like you've got pictured, but it's got two sizes...5/16 and another (can't remember..)
Works good....on our suburban.
I find the compact GM wrench pictured one of the easiest tools for the kids to get me,all I have to say is "Get me the battery wrench" :D
