Blinkers and Running lights?!!
96EDGEpsd
Welding/Fabrication
New York
can anyone explain to me how the front blinker and running light assy comes out?? i cant find any screws and it looks like they are attached??:dunno
stroked 350
coventry,ct
thay are bolted on from the back. look down beetween the batt. and the rad. support you should see 2 studs & nuts sticking out.
93turbo_animal
Marengo,ohio
never could see them on mine take the battery out then look but the rad support is double walled so the you have to find the holes that allow access to the nuts they should be level with the middle of the turn signal lens
96EDGEpsd
Welding/Fabrication
New York
:thumbs thanks but i was able to do it with only taking the grill out, thank god, i put in 4 strobes, ill take some pics and let yall kno how it turns out
