Question Boost fooler regulator and tee for boost gauge
aldo_45030
Harrison, Oh
I am using the vacuum line to the boost sensor as my tap in for my boost gage. I would like to install an air regulator style boost fooler. Can i put both in that line? Shouldn't the pressure be what is really being generator before the regulator and what the sensor sees the fooled amount?
MBRPCrazyford
Eat Some Smoke
Harrisburg, PA
Yes, that's correct. You should be able to fit both in that line. Make sure you get everything sealed up GOOD cause ya don't want a boost leak.
