boatin said:This site diagnosed my miss
I was wondering what causes the v/c harness to burn?![]()
clem said:You will have to at least change the bad GP so you don't fry your new harness.DO NOT USE AUTOLITE GP'S. They tend to swell over time then you can't pull them out. Stick with Motorcraft Beru's. Don't rush taking the old one out in case of carbon build up on the element.If you break it off chances are you will have to remove the head. If it's hard to come out use alittle carbon cleaner on it from the boat shop and work it out slowly. Good luck.
Are the plugs on the wiring harness a snap plug or just a regular plug. I'm showing me age but with bi-focals I can't tell what kind they are and I don't want to break the harness?BJS said:Nope you don't have to unplug anything as a matter of fact you can unplug the outer harnesses while the engine is runningbut don't lick the connector it'll shock the heck out of you.
threejacks most of the time you have to actually pull the valve covers off to find the damage. There are some times when there is such an electrical draw that the connectors @ the valve cover gaskets are damaged and you can check those easily but the harness that usually burns up is the under valve cover harnesses that go directly to each injector & glow plug
