Cat delete pipe
chrispugs1967
chrispugs
north haven,ct
OK, so I'm ready to let my kitty go, I see that everyone talks of MBRP's cat delete pipe. I'm confused because it says it's For Use with MBRP 6.0L Aftermarket Exhaust Systems. Will it fit on to my stock 03 exhaust system?
Dogman
tampa,FL
I don't know about that. But I just cut the cat. out and welded in a 3 1/2" chunk of fence pipe for mine. I just could not see spending $150 for a cat delete pipe. For a stock Exhaust Systems.
DONT cut the cat out...youll never be able to put it back in (w/out a
welder, etc) !
The MBRP test pipe fits the stock exhaust (and just about every after
market system out there).
the MBRP test pipe is EXACTLY the same length & size (including the
flange & bolts) as the factory CAT.
Ive personally installed THREE of the MBRP test pipes, one on a completely
stock factory set up, one on my own mbrp turbo back system & one
on a factory/silverline set up.
Ive swapped the pipe in and out w/ the cat on TWO of the three trucks,
its an EXACT fit, no cutting, no welding <EVER> !
