center seat removal
sagebel
Stock? Pfft!
Albuquerque, NM
You need to unbolt the front bolts on the driver and passenger seats. I don't remember if they share rear bolts. If you look you will be able to see the bolts. You will need to move the seats forward and back to access the bolts. Front bolts use a torx head. For easy removal from the truck, pull the passenger seat out and take the center section out the passenger side. Don't forget the electrical connector under the seat (if you have power seats).
You should be able to change out what you have, for a bench seat. The bench seat bolts up using the outboard bolt holes and nothing in the middle. Seat belts will work.
