Check engine lite
highflier
Austin Texas
i HAVE A BANKS EXHAUST AND AN S&B AIR INTAKE WHICH HAS A HOLE FOR THE HEATED AIR TO ENTER THE AIR INTAKE AT FIRST I PLUGGED THIS AND THE HOSE. THEN I PUT THE HOSE INTO THE AIR BOX SHORTLY THERAFTER THE CHECK ENG LITE STARTED APPEARING AND DISAPPEARING RANDOMLY, SO I PLUGGED THE HOSE AND PROBLEM SOLVED
ANYBODY HAVE THIS SAME PROBLEM
EVENTUALLY I WILL HAVE A TUNE AND DPF DELETE
johnkid
CA , HERMOSA BEACH
yea i did i pugged the hot air hose on my s&b intake my check engine light came on when i floored it , i also got 5" from the dpf bak with a rbp 6inch tip the code the truck throws is P-2002-PF it calls for low threshold of dpf filter i have a programmer and i clear it whenever it comes on it comes on maybe like every two weeks its just to much airflow i was told if you could find a dry filter for the s&B it should solve the problem
