Climb safely with Aries ActionTrac Running Boards + New Rebate
Are you looking for the perfect step for your lifted Ford truck? Aries has it for you! Its ActionTrac powered running boards give you two steps in one. This patented step-within-a-step design, combined with a no-drill bracket installation, control module operation, and powder-coated aluminum construction truly makes these retractable running boards the best addition to your truck.
They feature no-splice wiring and a no-drill bracket installation, as well as integrated LED lights that illuminate the power side steps upon opening. The power step drops 8" when the door opens and up to 15" below the doorsill. Get easier access into your Ford truck and take advantage of the new Aries Promotion at CARiD!
Today you have a great opportunity to get a $100 Prepaid Mastercard with the purchase of any Aries ActionTrac Power Running Board kit. The offer is valid till August 31, 2020. Please complete the PDF form to get your gift.
Aries® - 3.3" ActionTrac™ Retractable Black Running Boards
Features:
  • Patented step-within-a-step design for easier access, especially on large vehicles
  • 3" powered step automatically drops 8" when door opens, up to 15" below doorsill
  • 4" top step provides convenient access to the roof of the vehicle
  • Housing shields retractable step, pivot points and electronics from the elements
  • Contoured design helps protect the rocker panels from road debris and door dings
  • Simple-2-install system with no-drill brackets and no-splice wiring
  • Powder-coated 6061-T6 aluminum is durable, lightweight and non-corrosive
  • Integrated control module detects obstructions and eliminates pinch hazards
  • Single, rotary motor for fast, quiet, maintenance-free operation
  • Integrated LED lights activate on deployment for added visibility and safety
  • Rated for 650 lbs. static weight capacity (limited to mounting structure)
  • Limited lifetime warranty (five-year finish and three-year parts)
