code P0470
doug young
Snohomish, Wa
Code P0470 Exhaust Pressure Sensor Malfunction
Can sombody explain in english what this really means. i understand what is says. but i need a literal translation. and is this the same sensor that is used for the EBPV located at the front of the engine?
thanks doug
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
thanks doug
It's very possible that the tube that goes from the front of the pass. side exhaust manifold to the EBP Sensor is plugged with soot.
My tube had a hole in it, so I removed it, plugged the hole in the manifold and replaced the sensor with a dummy module to prevent the PCM from throwing codes.
doug young
Snohomish, Wa
so how does that work in the colder weather when your truck needs to close the back pressure valve for the extra heating?
