code po470
LAPLANT
Flowood MS
ran the scanner on my truck today just for chits and giggles no check engine light on or anything
came up with p0470 exhaust back pressure sensor malfunction
yall think i should just replace the sensor
the truck is stock tune with the zoodad mod and a k&n
it has 204000 miles on it
99 4x4 super cab F250 born 2/99
I'd inspect and clean the EBP sensor connector first, then under the Dash.. pull fuse # 15.. (or disconnect the Batts) for 20 minutes to erace the code (from the KAM) from the PCM.
Scan it again.. see what you git ?
check the sensor tube going from the sensor to the front of the pass manifold. They have been know to rot to pieces.
