Help Needed Cruise control still not working
mspainting
Painting The Town
Little Rock, Arkansas
Cruise control still not working 2000 f-550
hey guys i talked about this about 2 years ago but found a wire on the back of truck for the trailer rubbed raw, burned up, it was the green 1 burned up my switch on my brake peddle and the plug for the switch, got the plug and switch fixed re wired the plug for trailer, put the wires in loom had the switch wires on master cylinder changed for the recall, checked switches on steering wheel good, checked fuses good, changed the vss senser on rear end still no cruise also changed the cps no change, any other ideas, there is no third brake lite on truck where lite is is a rubber plug to plug up hole so no water comes in truck, could it still be wiring the cruise worked for a few years after i bought it but has tow bed on it and the wiring was not a good thing tried to rewire what i could tell was bad
thanks sherm
