dana 60 model identification help needed
superdub01
SDD USMC/Wyotech
jacksonville nc
Hello all. So long story short, I was pulling another truck out when I sheared my front Dana 60 pinion gear right at the pinion seal. Now I want to order the new gear set and install kit but I am having some trouble identifying exactly which axle I have, and my build codes are mostly worn off of my door sill. A lot of ID information I find online seems to be conflicting with one-another. the truck is a 2001 S.D. 7.3L lariat 4X4 crew cab long box. can anybody help me with some dimensions, or bolt pattern info or something like that? Thanks in advance guys.
-Shawn :dunno
is there a tag bolted to the diff cover? (there should be)
the BOM number should be stamped on the long tube of the front axle.
Here is a good article about the D60 on Pirate
superdub01
SDD USMC/Wyotech
jacksonville nc
no there is no tag on the front diff, the previous owner must have removed it. but that is a good article from pirate4x4. thanks Brandon
