Question Dang Dawgs, tore up some wiring, do you know what this is?
Coloradohorsehau
Berthoud/Colorado
Well I suspect I had another mouse take up residence in my 2000 F250 SD, 7.3. I found a wire protector and terminal on the ground under the passenger front wheel well. Investigation showed the dogs tore up a little of the wheel well insulation and stripped the terminal and a cable protector from two yellow wires that go up behind the plastic wheel well. I checked in the same location behind the driver side front wheel well and found an identical wire with terminal that is attached to the plastic wheel well liner. It is just above the parking brake cable. Does anyone know what the damaged terminal is? I sort of suspect running lights for running boards but don't know for sure.
