Dash Question
Trapper77
2003 Owner
Albany Oregon
How does the dash come off? Just pull and the dash cover comes off? Also, I aqcuired an airbag on/off switch from a wrecked 01 for my 03, is this just a direct plug in to the switch?
Thanks
Trapper
the "shroud" around the factory gauges just pulls off...
tilt your wheel down.
I cant remember if you have to pull the radio or not...
the tricky part is the headlight switch... you have to remove the
knob 1st & then pull the switch out (there are two spring tabs)
remove the switch & disconnect it and then pull the schroud off.
Knob Removal pictures from cars photos on webshots
heres a good visual set of photos of the dash being removed.
http://www.brandmotion.com/manuals/Ford_Super_Duty_iPod_Installation_2007.pdf
nascar_fan28
IL
yeah it just pulls off, and you dont have to take out radio
