Diesel emissions and emission testing
Skweeker
Resident Guinea Pig
Trappe Pa
Does anyone know what California, Arizona, Colorado or any other states are doing right now concerning emissions testing on the light, medium and heavy duty diesel trucks??
Does anyone know what these or other states have or are working on in relation to testing the new diesel engines hitting the road now???
There is a lot of information on this, but nothing definite as far as when it will happen. Google; "Diesel truck EPA testing in California" (or any other state).
Arizona is doing some...but only in large metro areas.
NONE in Texas, or Virginia (where i recently moved from).
the tests so far consists of emmissions equipment (must be
in place) and they connect to & check via ODB2 connection
for codes ('case the CEL or MIL light BULB is out or pulled).
the SNAP test is done by some WANK...and its been reported
that theyve been HOLDING the throttle open for 15-30seconds...
unaware of the PROPER testing proceedure...what part of SNAP
dont they understand !
Arizona <metro areas> is performing opacity test (checking
for HIGH LEVELS of SMOKE)
SO MUCH FOR ALTERNATIVE FUELS in TUCSON & PHOENIX (SEE ANNUAL TEST PRICE)
All 1967 and newer diesel powered vehicles registered within the emissions control areas of metro Phoenix (Area A) and Tucson (Area B) are required to be emissions tested annually. The only exception is for apportioned vehicles, which are commercial vehicles that are licensed in multiple states. Diesel vehicles pulling trailers will not be accommodated at the inspection stations.
Diesel emissions testing in Pima County and for light-duty (8,500 lbs GVW and less) vehicles in Maricopa County consists of loading the vehicle on a dynamometer and measuring the opacity of the exhaust plume. The measured opacity must not exceed the established maximum. In Pima County the maximum allowable is 30 percent opacity. In Maricopa County the maximum allowable is 20 percent opacity. (The maximum allowable is determined by the average elevation of the registration area).
Heavy-duty (8,501 lbs and greater) diesel vehicles in Maricopa County are tested using the Society of Automotive Engineers J1667 test protocol, commonly referred to as the "snap-acceleration test." The test consists of measuring the opacity of three, wide open throttle, no-load accelerations from idle to maximum governed engine speed with the transmissions in neutral. The average opacity for the three accelerations cannot exceed the applicable standard for the model year of the engine. The maximum allowable for engine model year 1991 and newer is 40 percent opacity, for engine model year 1990 and older the maximum is 55 percent opacity.
Diesel powered vehicles may be tested at any of the vehicle emissions inspection stations in Maricopa County. In Pima County, heavy-duty diesel vehicles (26,000 lbs GVW or greater, or any truck with tandem drive axles) must be tested at 6661 S. Renaissance Dr., Tucson, AZ 85746.
Testing Fees
All diesel vehicles driven on a dynamometer must be operated by station personnel. The driver will be asked to exit the vehicle or move to the passenger seat. Vehicles tested using the snap-acceleration test will be operated by the person delivering the vehicle for testing. In addition to the opacity test, the vehicle will be checked for the presence of an appropriate fuel tank cap.
The owner of a diesel vehicle that has failed the emissions test twice, and who has attempted repairs that meet or exceeded the maximum repair cost limit, can apply for a waiver. If a waiver has been granted for a particular vehicle since Jan. 1, 1997, the vehicle is not eligible for another waiver. The maximum repair cost limit applies only to the cost of repairs that address the area of the failure, the amounts are as follows.
Vehicle Model Year ....................................Phoenix / Tucson
Heavy duty vehicles (26k lbs GVW & greater).....$500 / $300
All vehicles with tandem drive axles..................$500 / $300
1980 and newer............................................$450 / $300
1975 - 1979.................................................$300 / $200
1967 - 1974.................................................$200 / $50
Pre-1988 Diesel Engines and Vehicle Emissions Inspections
If you've received a letter from ADEQ regarding a diesel-powered vehicle with a gross weight greater than 26,000 pounds that must meet 1988 or newer emission standards, you can click on the following to obtain a copy of the appropriate form.
Remanufactured engine
Replaced parts
Retrofitted engine
Current engine meets 1988 or newer standards
Area A Map for Pre-88 Diesel Engines
Arizona Tailpipe Standards (40 CFR Part 86) for Pre-88 Diesel Engines
