diesel engine heater
Discussion in 'General Super Duty Discussion' started by roble1, Dec 23, 2017.
  1. roble1
    roble1 roble1
    14
    Apr 19, 2015
    Decorah Iowa
    I just looked for the cord for the engine heater on my 2013 6.7 and there isn't one. I don't normally drive my truck in the winter months but why would Ford not send every diesel out with an engine heater? Are they block heaters or where would one go if I wanted to add it? Merry Christmas Everyone!!
  2. 01yellerCobra
    01yellerCobra Full Access Member
    310
    64
    Jul 18, 2015
    San Diego
    Not everyone needs a block heater. It never gets cold enough for one where I live.
    I always thought the heater replaced one of the freeze plugs.
  3. RSG
    RSG Full Access Member
    736
    10
    May 29, 2006
    Savoy IL
    Yep, $90 option on the new trucks.
  4. snicklas
    snicklas Super Moderator Staff Member
    44
    397
    19
    Aug 10, 2008
    Greenfield, Indiana
    Well, funny you ask.
    This started back in the 6.0 engines. Every diesel engine built by IH/Navistar (6.9/7.3 IDI, 7.3/6.0/6.4 PSD) had a block heater installed. Even all the way back to the 6.9 IDI in 1983, when Ford put the engine in the truck, they installed and routed the cord to the front into the area behind the bumper. This was standard practice on all diesel engine installs, E and F series into the 6.0 equipped vehicles. The early 6.0's (like my 03 Excursion) also had the block heater cord. Sometime during the 6.0 run, maybe the 05 grille/headlight change, Ford changed the policy. If the vehicle was not sold into a "cold" environment (not sure what the Ford official definition of cold is) then it would not receive a block heater cord. However, if you wanted a block heater cord and weren't in a "cold" environment, you could buy one from the parts department, as and accessory for $90. Or goto an IH/Navistar dealer and buy one from them for $25-30.......
  5. stever01
    stever01 SDD Junior Member
    15
    Jan 31, 2006
    Ohio
    they tuck the cord really good up behind the passenger side tow hook if yours has one.
    stever01
  6. thumper111
    thumper111 SDD Junior Member
    64
    Dec 6, 2013
    Sudbury On.
    I would not worry too much about it. They will start down to -40. We get a lot of that here and the 2 I have owned have never missed.
  7. RSG
    736
    10
    May 29, 2006
    Savoy IL
    Dude...come try my truck w/o heat at 0F. Bring a jumper and a salamander.
  8. 79jasper
    79jasper Full Access Member
    25
    202
    16
    Aug 9, 2015
    El Paso, TX
    Really? Maybe you need to do some maintenance.
    My dinosaur 7.3 starts. A little Smokey, but starts right up.
    Sent from my SM-G892A using Tapatalk
  9. thecroz
    thecroz SDD Junior Member
    59
    8
    Nov 9, 2014
    Bay Area
    It doesn't get below freezing around here (30's to 40's) but my Rig sure likes starting on a warm engine.. It's quiet and the cab is nice and warm when I get in... Just-Sayin.. CROZ..
  10. RSG
    736
    10
    May 29, 2006
    Savoy IL
    Really...used to be good to 0 to -10 range, although plugging it in is best. I think it's a combo of the fuel, the tired but all working glow plugs, the old but still buzzing injectors. Batteries aren't new but solid, no corrosion anywhere. The only other thing different is I put in a new starter and it cranks faster, which should be a help, but I've 'let go' of the switch a tad too early at least twice this winter and missed my chance to catch the fire so to speak. But now my block heater cord is fixed and it fires right up. Without it, not reliable at all at or below around zero F.
Share This Page
