diesel leak question again
dcathey
Brunswick, GA
I have just replaced O-rings with viton 202 1/2od 1/4id and I am still getting the leak out of the drain onto framerail pretty bad....Is the valve bad or something else? At first it was because the valve was turned the wrong way and then I switched it and slowed but it is still pretty severe....what do I do?? Let it run longer to see if it is fixed or does it need to be replaced?
