Do Power brakes get their "power" from....
Scot
Howell, MI
the power steering??? I've had a few problems recently where both go out at the same time. Usually just for 1 stop/turn and then everything goes back to normal. Fluid level is fine. Belt is still there.
Any ideas?
Any ideas?
Yes. Your Brakes & Power Steering both get their hydraulic pressure (Power) from the power steering pump.
One thing you can try ?
Turn the wheels FULL left, Then Full right, 'til you here the Squeal.. Bump it against the squeal 3~4 times.. then check the fluid level.
You may have some air in the system.. doing the above, will purge most all of it.
Do it again, in a couple'a days ?
joe
