double din?
IHC Power
STOCK STROKE
Walpole Mass
Double din install
Not too much, you gotta trim the inside of the dash where the factory radio sat. Other than that i strongly suggest using a dremel if you got one. Also install the i assume tv into the dash then reinstall the dash into the truck. Good luck.
