Draw-Tite Tow Beast
Diesel4E
New Jersey
Any ever used the the Draw-Tite Tow Beast to tow the max capacity of 12,000lbs. without a W/D system? i would like to know your opinions because im thinking of getting on to tow my 12,000 lb. dump trailer.
Draw-tite makes good equipment. If they rate it for 12,000 lbs, then it is good for 12,000 lbs. I would not worry about it.
The hitch on my 06 is rated to pull 15000 LB. from the factory. It is a 2 1/4 in hitch instead of the 2 in like most are. I was told it is called The Tow Beast. I am sure it will pull any thing that the truck will pull.
