DRW axel nut
atk
Moderator
simcoe, ontario, canada
if you are talking about wheel nut, should be around 160ft.lb to 175ft.lb...if i was at work i could give you exact torque....hope this helps....
if you are talking about rear hub nut....tighten to 70 ft.lb, back off nut 90 degrees and tighten to 18ft.lb....hope this helps
atk
Moderator
didn`t think you had to pull off the hubs when changing rear rotors...i know on the SRW you don`t....didn`t think the DRW were different...anyway, the torque spec. and sequence in my previous post should be accurate for the hub nut....
