JOAT
I Found Nemo!
My AC has been getting to where sitting in traffic it would cycle off, then wouldn't come back on till I got moving. Pressures were normal when the compressor was running. I then found the compressor clutch wasn't engaging at low RPMs when the system had been on awhile. Checked the manual and found the clearance on the clutch should be .014-.033" and mine was .045! I took a washer/shim out from between the cluch hub and the compressor shaft which left me with about .012 clearance. It has operated flawlessly since.
