ECU and TCM reflash programmer?
dubious
dubious
Calgary Alberta
Forgive my ignorance.
I currently own a GM, but seriously considering a F350.
The Gm guys get access to an ECM and TCM programmer called EFI live
it allows the owner to customise and build his own tunes, or alter canned tunes.
We can change fuel injection dwell and duration, pressures, boost pressure, trans shift points for every gear, stall and a just about anything the stock computer controls.
Does anybody have such a device for the Fords?
I am about fed up with my allison trans, and the IFS.
I like the solid chasis on the Fords I drive at work. They stand up to alot of abuse.
Thanks,
Lyle
ckamp52
ckamp52
italy,tx and stephenville
a lot of guys including myself run the sct or sct livewire its basically the same thing it comes with preloaded tunes and you can get custom tunes for however your truck is set up
