engine covered with oil?
bonestroker
stroke it if you got it
In the field
its comming out of the cover on top of the valve cover. Its spitting iol out and going in to the turbo:dunno
txastuff79
texas
pull the oil fill cap... how much blowby is there? our trucks have some but not as much as i think your gonna find.
The Orings for the CCV cover may be bad and need replacing,the rubber CCV 90 degree tube may be loose,cracked or plain leaking.
I believe blowby increases at varying percentages with every engine.
Might need to do the CCV mod there Bone.
jvencius
In a van down by the river...
Yep--when I did the CCV mod and flipped the breather front-to-back, I lost one of the o-rings and it made a TREMENDOUS mess. Like CHP said, if an o-ring is broken/missing, that would be an easy (and cheap) fix.
drivers side of the motor covered in oil and with no boost and the motor shimmies
What everyone has said, AND... theres a bolt headed plug on the head, between the valve cover and the block. They have and O ring.. check those.
The no boost part makes me think: I/C boots & tubes tho..
:dunno
