Ensure smooth braking with Curt Assure Proportional Trailer Brake Controller
New, reliable, and highly responsive Assure Proportional Trailer Brake Controller by CURT is a perfect solution that will help you effectively tackle all your towing needs! It is engineered specifically to provide you with constantly updating data about the current state of your brakes, offer precise braking power with just one press of the button, and automatically adjust the power output when you’re going up or down a hill.
It is an innovative controller that features a motion-sensing accelerometer, a pressure-sensitive manual override, and a high-quality 1-1/2" wide, 128 x 64 dot-matrix OLED display.
CURT - Assure Proportional Trailer Brake Controller with Dynamic Screen
Features:
  • Pressure-sensitive manual override button for precise braking power
  • Large, high-quality 1-1/2" OLED screen displays full text readout
  • Triple-axis, motion-sensing accelerometer for highly responsive, smooth stops
  • Third axis provides dynamic power adjustments when going up or down a hill
  • Display can be tilted for different mounting options, above or below the dash
  • Diagnostic alerts notify of potential problems like low voltage or disconnect
  • User-selectable power output and trailer brake light activation
  • Automatic leveling and calibration eliminate setup requirements
  • Mountable at any angle up or down in the vertical plane
  • Nine levels of sensitivity adjustment for varying loads or driving conditions
  • Auto sleep mode prevents battery drain
  • Equipped with a quick plug for easy, plug-and-play installation
  • Built-in reverse-polarity and short-circuit protection
Hop over here to find out more about the new Curt release.
