exhaust brake
Discussion in '6.7L PowerStroke Engine & Drivetrain' started by keith jolley, Dec 27, 2017.
  1. keith jolley
    keith jolley SDD Junior Member
    Feb 9, 2017
    Adin,ca.
    I have a 2016 6.7. the exhaust brake seems almost non existant.My dealer says there is nothing they can do that's just the way it is set.Does anyone know if they can get more aggresive through the computer?
  2. 01yellerCobra
    01yellerCobra Full Access Member
    366
    73
    Jul 18, 2015
    San Diego
    How are you using it? I've found it best to have the engine around 2500rpm when I use it. I usually put the trans in manual and lock it at a lower gear. I can stay at 65 while towing my car down a 6% grade without touching the brakes. Sometimes I have to turn it off because it keeps slowing me down.
  3. keith jolley
    Feb 9, 2017
    Adin,ca.
    I use it towing my 5th wheel.My Dodge would slow you down immediatly.It also had the cackling sound.
    The Ford has no noticeable sound or feel.Ihave disc brakes on the 5th wheel,so I have plenty of stopping power.I am just dissapointed in the Ford brake.
  4. 01yellerCobra
    366
    73
    Jul 18, 2015
    San Diego
    Maybe try downshifting manually when you use it. I've found if the RPM is too low it doesn't work as well.
    Did your Dodge have the DPF? That thing muffles a lot of noise.
  5. 79jasper
    79jasper Full Access Member
    26
    222
    21
    Aug 9, 2015
    El Paso, TX
    I'm sure tuning can be done to make it better.
    Sent from my SM-G892A using Tapatalk
  6. FiveOfastback
    FiveOfastback SDD Junior Member
    7
    Nov 3, 2013
    Bethlehem, Pa
    Does truck have tuner installed now?
    All tuner and tunes I know of only have exhaust brake on stock or tow tune. I have a del;6;3: 2016 with tyrant tunes and only get exhaust brake on Tow Tune.
  7. dburress
    dburress SDD Junior Member
    Mar 31, 2009
    Lakeland, FL
    If you don't have much of a load, you will not notice it. I used it up in the mountains with a 36' gooseneck trailer and it never ran away from me. It just doesn't sound like a big rig.
  8. RSG
    RSG Full Access Member
    754
    May 29, 2006
    Savoy IL
    I use it even as an unloaded daily driver. I absolutely feel a difference in stopping.
  9. 01yellerCobra
    366
    73
    Jul 18, 2015
    San Diego
    I showed my wife and son how to use going through the mountains in Oregon. They both got a kick out of it.
Share This Page
