exhaust brake
doug young
Snohomish, Wa
hey boys need some advice. i have been looking at Pure Diesel Power website and found an EBV Exhaust Brake system. i talked to a guy there and he told when the system is activated it is equivilant to the truck down shifting a gear. it is not as pronounced as an acual Exhaust Brake system. Are any of you familiar with this particular system? would i be better off doing a DIY exhaust brake? i have a camper i haul around and would like a little help in sloweing down my truck without eating up my brakes. i have a 1999 f250. thank doug
CSIPSD
Bend, OR
I installed a SP diesel TC controler and exhaust brake kit a few months ago, great product. A little more money then the others but its all plug and play. Works off of the cruise control buttons, you can set the lock and unlock speed of the TC...
http://www.spdiesel.com/
doug young
Snohomish, Wa
isnt there a diy article that tells you how to create your own exhaust brake with the back pressure flapper?
Crazyhorse
Suisun, CA, USA
allthat is in their "kit" is a pigtail to cut up to use the back pressure flapper (EBV = Exhaust Backpressure Valve)
CSIPSD
Bend, OR
Hum...NO...
It is a converter lock up controler, and a exhaust brake controler, I can set the lock up speed of the TC by holding the SET button on the cruise control, I can set the unlock speed by holding the COAST button, this is then all automatic. When I hold down the OFF button for 2 seconds the exhaust brake comes on, touch the gas, its off, let off again its back on...Turn the cruise on and the brake is off...
Yes it does use the EBV as the braking force... But it is way more then a "pigtail to cut up to use the EBV" as you put it:roflmao ...
I can set the TC to lock as low as 12mph and to unlock at 15MPH...
Crazyhorse
Suisun, CA, USA
CSIPSD said:
Hum...NO...
I was referring to the setup that was posted from Pure diesel power, since that's what the original poster asked about... Not what you posted. I was just pointing out that since he asked if he would be "better off doing a DIY exhaust brake?" that he still would be doing that with PDP's setup, just w/o cutting the harness...
CSIPSD
Bend, OR
My apologies...:oops: Its been a long day, wife is on vacation (has been for 4 days...) and I have the kiddos... got to take them to work too...:eek: Good kids just LOTS of work!!!:roflmao
This is lifted from Steve Baz's web page which can be found HERE. Keep in mind that this tutorial was written several years ago and intended to be used on the 94-97 year class trucks so................. with that said, see if you can apply it to your truck. I have not tried this mod, matter of fact I removed my EBPV so I offer no warranty or garuntee implied or other that this will work, proceed at your own peril. :sweet
Exhaust Brake - Make one by Doing It Yourself
Mod & Article by Jonathan Ryan
The Engine Exhaust Back Pressure Valve (EBPV) is a butterfly type valve located on the outlet of the turbocharger, between the turbine and the down pipe. It is controlled by the Power train Control Module (PCM), and activated by engine oil pressure. Its purpose is to decrease engine warm up time in cold weather by restricting exhaust flow out of the engine. It can be very easily and very inexpensively converted into an engine exhaust brake by adding some simple wiring and a switch.
The valve is very practical for assisting braking. When used correctly its braking effect can be compared to the restriction gained by downshifting one gear while descending a hill. The valve is most valuable to braking when engine speed is between 2500 and 3000 RPM. Unfortunately, it will lose the engine braking abilities when engine speed drops below 2000 RPM.
The following method outlines the manner in which the EBPV can be converted to a braking device. The following will cover any vehicle equipped with a manual transmission. Vehicles equipped with automatic transmissions will require an additional circuit to be added in order to maintain torque converter lockup while the exhaust brake is activated. That circuit will be addressed at the end of this article, however the majority of this article is applicable for both transmission types.
EBPV Schematic at http://community.webshots.com/photo/31332816/33154054yrQYVH
In order to control the function of the EBPV, I recommend using a 3-position switch. This type of switch will control the Valve in the following manner:
Switch in the OFF Position (center position): The EBPV will function normally, as it would for a stock vehicle. This means that the valve will only actuate in order to warm up the engine.
Switch in the "A" ON Position: the EBPV closes and remains closed until the switch is turned OFF.
Switch in the “B” ON Position: the EBPV will close whenever the brake pedal is pressed, and will open when the pedal is released. There will be a 2-3 second lag for the exhaust valve to close upon stepping on the brake. Thus, it is important to understand that when using it in the "B" ON position to push the pedal and hold it down with steady pressure. The reason for keeping pedal pressure is that the EBPV actuator is receiving power from the brake light circuit when the switch is in this position. Thus, pumping the brakes or releasing the pedal will cause the valve to deactivate or open. Furthermore, once the brake is applied again it will take another two seconds for the EBPV to activate again. Unfortunately, pumping the brake pedal will result in the exhaust valve remaining in a constant open position. This will provide ZERO engine braking force. To prevent this less than desirable phenomenon from happening, it is important the operator keep his foot on the brake lightly enough that the brake light switch is continually activated. I prefer touching and holding my pedal just hard enough for the brake lights to come on; then, when I hear the EBPV close (it makes a distinct hissing), I begin applying additional pressure to the brake pedal. Reducing brake pedal pressure can be done without losing exhaust-braking force, as long as there is enough pedal pressure maintained to keep the brake lights on.
Materials:
(1) ON-OFF-ON type Heavy Duty Double-Pole Double-Throw (DPDT) toggle switch. It will have connections for 6 wires on the back, and the switch will have 3 positions UP=ON, CENTER=OFF, DOWN=ON. RS (Radio Shack)# 275-1533A $2.49 or 275-710 $2.99 · 25'-30' of 18 gauge wire. 5'-7' each of 4 different colors is best. · (10-12) Ring or Spade terminals for wire connections. 18-22 gauge are red. RS# 64-3032A or 64-3033A $1.49 (4-6) Butt connectors for wires. 18-22 gauge are red. RS# 64-3037A $1.49 · (2) Rectifier Diodes. A diode is the equivalent on an electrical check valve, allowing current to flow in only one direction. RS# 276-1114 · (2) Optional Mini Indicator lamps. RS# 276-085A (red) 276-084A (green) $1.99 each. (By using the switch indicator lights, the operator immediately knows how the EBPV is activated or not.) · 10' Split loom for protecting wires. RS# 278-1264 $3.99 · (10) Wire ties. · (1) Inline fuse holder. RS# 270-1213 $1.99 · Electrical tape. I recommend Liquid Electrical Tape as being better for almost everything. · Tape and Marker (In order to label wires.)
Tools:
Wire cutters/strippers · Screw Drivers · Drill w/ bits up to 7/16" · Volt/Ohm Meter, or at least a test light. · Soldering Iron is recommended but not essential. · Torx bits &/or 1/4" drive metric sockets to remove dashboard trim to install switch.
Procedure:
Decide on a place in the dash to install the switch. I installed mine in the black panel just to the right of the "Wait to Start" light. There is room for 2-3 switches there.
Remove the necessary trim and molding around the steering column / instrument panel to access the reverse side of where you want the switch. Drill a 1/2" hole, and install the switch. Re-install the molding to make sure it fits into place when the switch is installed. Then, remove the switch and the molding again for ease of access while wiring.
Wire #1: Decide what you will use for a positive power source. Insure that this source is one that is "ON" only when the ignition is in the “ON” position. I recommend the 8 gauge, gray/yellow wire in the bundle under the steering column. You can also tap a fuse in the fuse panel. Run wire [#1] from the source to the switch, connecting it to terminal A2. I numbered the terminals as viewed from the back of the switch Install the inline fuse holder on this line. Make sure to leave 6"-12" or more of slack on all the wires. You can always bundle them up later.
Wire #2: Decide placement of a negative power point or ground, and run a wire from this to the switch, connecting it to terminal C1.
Connect one light to terminals A1 and C2; this is light A. Connect the other light to terminals B1 and C2; this is light B. Drill holes for the lights just above and below the switch. Install the lights with B in the top hole, and A in the bottom. I recommend this because when the switch is down, contact is made between A+C; when the switch is up, contact is between B+C. For simplicity, the diagram does not show the lights "crossed" like this.
Remove the black-hinged cover from over the fuel filter area in the engine compartment.
Wires#3 & #4: Run two wires from the switch through the firewall into the engine compartment. Connect one [#3] to terminal C2 and run it to the front of the engine. Connect the other [#4] to terminal B2 and run it to the brake master cylinder. If you have a horizontal diamond shaped plate about 2.5" wide just to the passenger's side of the clutch cylinder, remove the screws and run the wires through it. Otherwise, you may need to drill a hole. I always find that running the wires is the hardest part of any wiring project.
There should be a green wire by the driver's side of the master cylinder in the group of 4 marked "Center High Mount Stop Lamp Feed." This wire most likely will not be connected to anything. This wire is only energized when the brake lights come on. Connect wire [#4] to this one. If this wire is not present, use a voltmeter or test light to find a wire that is hot only when the brake lights are on and connect to that wire instead.
Locate the wires that travel from the PCM to the EBPV. There should be a 2-wire plug just under the turbo compressor. It is located towards the front of the engine between the turbocharger and the fuel pump on the intake side of the turbocharger. The plug is attached to the turbo pedestal. Disconnect this plug, and remove the loom (protective plastic shielding) on the plug side moving away from the turbo, to expose the wires inside. Slide off the loom until it reaches the intersection of the larger wire bundle. This will expose both wires; one wire is black w/gray, the other gray w/red.
The Two Rectifier Diodes that are required will each have a silver band around one end. Twist the wires from the "silver" ends together making a "Y.” The "black" ends will be at the top and the silver ends at the bottom of the "Y.” Cut the gray w/red wire 2"-3" before the plug, strip the insulation back 1/2" or so, and solder the black end on one diode to the end of the cut wire that does NOT go into the plug. Solder the black end on the other diode to wire [#3]; solder the two silver ends to the gray w/red wire that goes into the plug. The diodes are necessary to prevent the brake lights from coming on when the PCM operates the EBPV, and to prevent the PCM from receiving a 12v signal from wire [#1]. If you don't have a soldering iron, you can use crimp connectors.
Coat all the wire connections with several coats of Liquid Electrical Tape, then wrap them with regular electrical tape, and replace the loom. Also, cover wires [#3 & #4] with loom, all the way to the switch. Bundle up any excess wire with wire ties, and secure them all to prevent chafing. Install the switch in its hole, and replace the dash trim.
Automatic Transmission Circuit:
If the intention is to use the EBPV as a brake with an Automatic Transmission equipped vehicle, then an additional circuit is required in order to reap the most engine braking benefit from this application. This circuit will keep the torque converter locked up while the valve is in an activated state. In effect, it maintains engine RPM in relation to ground speed and prevents transmission disconnection, which would result in loss of engine speed, ultimately reducing the effectiveness of the exhaust valve as an engine brake.
Auto Trans Circuit Procedure: Run a wire from [#3] to connect to the TC lockup circuit. Install a diode on that wire with the silver end towards the transmission.
Testing:
To test, start the engine. With the switch in the up position, the upper light should come on when you press the brake pedal, and you should hear a distinct hissing or swooshing sound when the EBPV closes, after 2-3 seconds. With the switch down, the bottom light should come on and stay on, and the EBPV will close immediately.
Conclusions:
I find no advantage to using the EBPV brake with an unloaded truck during normal driving. However, when I am hauling a heavy load, it is worth its weight in gold. During normal hauling, I leave it in the up position, so I will have extra braking power when I need it. For exit ramps and long or steep downgrades, I put it in the down position and leave it on as long as practical. When the truck is parked, you can leave the switch in the down position, as it is useful as an anti-theft device. The activated valve will not allow the truck to go much over 33 mph. This is also very useful for very fast warm-ups in winter.
I use my EBPV as a exhaust brake and it is very useful. At higher rpm it will hold back a quite a bit. Go with the DIY setup as there is no need to pay big bucks for something you can do for a few bucks.
doug young
Snohomish, Wa
ok. hold on this is getting confusing. its like playing that game as kids, where you all sit in a circle and tell the person to the left of you something, and they pass it to the next and then the next until its gets all the way around the circle. and when it gets back it sounds nothing like what it started out to be. so crumm your answer sounds the best. how do i utilize the EBPV as a brake. and would i get better braking "power" doing it that way verses buying the unit from Pure Diesel? i understand that if i bought an actual exhaust brake unit then i would get the greatest "power", but i dont want to spend that kind of money. im only hauling a camper, so some help in braking is all i need. i could have sworn i read a DIY article in the wiki section some time ago on how to do this, but i cant find anything now.
thanks crumm......doug
