Question Exterior Temp sensor
85buggy
Medina OH
My exterior Temp is reading like 50 when I know its only 30 or so out. I think maybe its coated with road salt or even ice,cause our weather in Ohio has been crap ++++. Where is the sensor located and can anyone give me any insight on this temp thing...
ponyexpress94
Diesel Power Junkie
Maryland
The outside temperature sensor is located behind the grille. Look in the upper left or upper right corners behind the grille shell and you should see a probe/sensor looking module that has a weatherpack style plug going to it with two wires. If you are sure the displayed temp is higher than the actual air temp I would start with a new sensor behind the grille.
Good luck, hope this helps.
