Help Needed fender above exhaust keeps turning black
dmd
Member
Double Oak, TX
If you are just concerned about the fender, then just add a turn down tip.
If all the truck has is the programmer, then it probably needs a better intake
and exhaust to let the air flow better and it will run cleaner. That or keep
your foot out of the throttle.
Butch Cassidy
Chelmsford, Mass
I cut off 2" off my exhaust - for ease of installing and removing the camper. Also took care of the "black fender syndrone"
Butch Cassidy
remod
Powell , Tn. U.S.A.
Ok guys , my diesiel has super chip tuner installed , oversized exhaust and k&n air filter ,which I keep cleaned and oiled , and I am not foot heavy on the throttle . Never had a problem with with smoke build up on fender until about a year ago , after Ford replaced rusted out oil pan . Thanks for all your replies , Bryce
dmd
Member
Double Oak, TX
Well I hope the engine isnt smoking more from gettin dusted by the K&N... That
would be bad... A clean K&N filters worse than a dirty one..
dserge66
