Fluids for F250 differential and transfer case
ProXJC
Michigan
Just wondering what I should use for oils in my 01 f250 transfer case and differential. Rear end is limited slip.
I use Royal Purple synthetic lubricants in the rear end and change it every 40.000 miles.
Yes I know that's overkill, but my truck tows a lot.
dboyw
Lancaster, PA
I use Amsoil ATF for the transfer case, and Severe Gear for the rear end.
trailey97
diff can only take so much till it trickles out if im not mistaking...same for transfer case too i believe...
Dieselpwrdredneck
Addicted2Diesel
paris, Ohio
look in the owners manual should tell ya my truck with the dana 80 rear an 60 front take about 7qt between the too if the books, correct
ATF (Merc V) in the t-case
Rear diff 75w140 Valvoline Synthetic in the rear diff
