front axel swap....
BigRedJeep
Mind if I Smoke
Louisville, Kentucky
just last weekend i swaped the front d50 (F250) axel for a d60 (F350). The ball joints were going and i thought what the hell its bigger!! Apparently they also tell me that im hard on stuff so upgrading is in my best interest.
my question.. Is the front driveshaft on a F350 shorter that a F250?? i dont have much play in the slip yoke ( about 1 to 1.5") to full compression.
atk
Moderator
simcoe, ontario, canada
how much travel did you have with d50 axle?
i hoping to do the u-joints in my front driveshaft this weekend, so i could give you some measuements....i do have a d60 axle....
yes the pinion is longer on the D60 resulting in a shorter driveshaft. If memory serves me right the pinion difference is around 1 3/4"
which you could just take to a driveline shop and have shortened
BigRedJeep
Mind if I Smoke
ok right after i posted the internet died on me. figures.. the rubber boot on the driveshaft slip yoke is pretty squashed. I did measure both axels and the d50 is 13 inches from diff cover to the back of the yoke. the d60 is 14 inches (about) so yea i guess when i get some time im gunna take it to be cut down.
to my knowledge all sd f250s have the d50 up front but i could be wrong. someone else is sure to know..
