Question Fuel in Oil
Discussion in '6.4L PowerStroke Engine & Drivetrain' started by Wes01, Jun 23, 2017.
  1. Wes01
    Wes01 SDD Junior Member
    62
    Jun 23, 2017
    West Plains,Mo.
    I thinking I have a fuel line leaking under the valve cover, does anyone know if one side is more likely to have the problem than the other??
    That is if that is the trouble? :(
    Thanks
  2. JLDickmon
    JLDickmon ursus combibo
    4,171
    I checked Identifix real quick.. there do not appear to be any TSB's on this, but a symptom search "fuel leak" brings up a string or repairs concerning leaking injectors, and every one of them has you pulling the valve covers and inspecting the lines first.
  3. stroked 350
    stroked 350 Full Access Member
    306
    Dec 26, 2005
    coventry,ct
    when these motors go into regen they add fuel to clean dpf whatever isn't burned off ends up in the oil I average 1 qt over full every oil change
  4. Wes01
    62
    Jun 23, 2017
    West Plains,Mo.
    L
  5. Wes01
    62
    Jun 23, 2017
    West Plains,Mo.
    Like 3 qts here !
  6. stroked 350
    306
    Dec 26, 2005
    coventry,ct
    I would guess it depends on how many times it regens as to how much fuel gets into the oil
Share This Page
