Question Fuel injector electrical plug availability?
Eubee
Mount Pleasant, MI 48858
Does anyone happen to know if it is possible to buy just the electrical plug (or pig tail, if you will), for injectors, that connect to the injector harness? My injectors work fine, but a couple have broken plastic bits on the plug as to where the clip has nothing to grab on one side; and once in a while they will pop off. I'd rather not replace the entire injector(s) due to it not being cost effective enough. Any insight y'all can give is greatly appreciated.
You can get the Under Valve Cover Harness to replace your broken one. Ford or International has them.
