fuel pressure regulator shim kit
Archichoke
Arlington, TX
What are the benefits of adding this to my cuurent system? I understand better throttle response and such, but is this still true after chipping the truck?
Thanks,
David
roosterdiesel
Earl needs B100
Amarillo,TX
Yes even with a chip you will notice a difference. The upped pressure will help the barrel of the injector fill properly. Next step would be to get rid of the dead end fuel system with a regulated return.
David if the regulated return isn't in the budget at this time I can shim your 7.3L if you like,just take 10-15 mins tops to prep and install. You'll like how your truck responds and sounds afterwards.
The benefits are good even with a stock system.
Archichoke
Arlington, TX
thanks, I may take you up on that. I do not have a fuel pressure gauge that goes over 60psi. I might wait till my next "mileage expense" check and do the regulated return too.
DW
I'll slap a test gauge on it to get the PSI just right then when you go to tackle the Regulated Return system I can help you with that as well.
police stroker
Dallas, Texas
Hey CHP do you think at Bartmans mod day you could help me washer my fpr and check it with your gauge??? or PM the link with what I need so I can do it myself.
I can help you with the washer and PSI testing any weekend before hand Justin:sweet
