Gain easier access to your cab with APG Steps + Promo
Designed to give you a leg up into your cab, truck running boards are things that all pickup trucks need. Not only do running boards look really cool, but they can also make life a whole lot easier. If that's what you're looking for, take a look at APG running boards.
They feature aircraft-grade aluminum alloy construction designed to withstand extreme road conditions, heavy loads, and door dings. For enhanced corrosion resistance, a matte-black powder coat is applied to each step. Your truck's rocker panels are protected from road hazards and trail obstacles with the step's reinforced tubing.
Get in & out of the vehicle more easily with APG Running Boards! Shop now and use this opportunity to save up to 20% on APG running boards, nerf bars, and side armor at CARiD. Do not hesitate! This offer is valid between November 1, 2021, and December 31, 2021. Prices are already reduced.
APG® - 7.5" Drop Down Style Black Nerf Bars
APG® - 6.5" T Series Cab Length Black Running Boards
APG® - 6" S Series OE Style Cab Length Running Boards
APG® - 2" Square Tube Black Side Armors
