gasoline in fuel tank
I'm guna say: NONE.
How much Diesel was in the tank.. and how many gallons of Gas.. Was put in ?
If you had half a tank, and put in three to five gallons before you noticed, you could dump in like half-a-dozen quarts of TCW-3 ashless two-stroke oil..
If you put twenty gallons in, you have lots of bunker fuel.
dpantazis
#12
under the cheddar curtain
mgrek-
are you saying that you have 120 liters of diesel and 20 liters of gas?
then yes, do as JLD recommends, add a whole bunch of 2 cycle oil, the kind you use for 2-cylce boat mix. get it by the gallon its much cheaper that way. canadian tyre, walmart, etc.. couple of gallons and then keep topping off with diesel. so about 50% ashless 2 cycle oil to gasoline to dilute then add more diesel.
