gauge question
bears4x4
grease monkey
katy texas
Which should i use for my svo temp gauge, a water temp gauge or a oil temp gauge, they are both going to me electrical due to cost is cheaper but both will be auto meter z series for matching effect.
hheynow
Señor Aceite de Soja
Northern California
What are each gauge's max & min range? The oil gauge usually has a hotter maximum. The vegoil temps mimic the coolant temps so I say water gauge. My water gauge starts at 100*F with a maximum of 260*F and since our engines overheat at 246*F it's perfect for water and vegoil. BTW the hottest vegoil reading I ever saw was 196*F with an ambient temp of 102*F and coolant at 220*F.
bears4x4
grease monkey
katy texas
ok thanks :)
How about a vacucm gauge for in thge dash instead of on the line to read
bears4x4
grease monkey
katy texas
ok i bought a vac gauge from autometer but the instruction only show installation for a air vac like on my boost, i want to use it for the vac on my vormax but in cab, do i just hook it up like a reg vac gauge but in the svo fuel line
hheynow
Northern California
The colored vacuum gauge on the Vormax unscrews. Use that port for your vacuum line connection. The Vormax colored vacuum gauge can be reused on your other filter head.
WorthLess :D
