Question Gauge sending wire placement through firewall on OBS
OBS96
Renton, Wa
I've got all my gauges now. EGT, Boost,Oil Pressure, and Water Temp. My firewall is nothing but heatshield,so I can't see what's under it, and I can't really see way up under the dash, and a lot wires. Not like the good old days when you could drill anywhere, and not worry about hitting anything. I'd like to run them all through the same hole, using a grommet where the wires will go through. Where did all of you run your wires through the firewall? :dunno
Thanks for all your help!
hheynow
Señor Aceite de Soja
Northern California
If it's an automatic drill a 3/4" hole through the black diamond shaped clutch plate. It's obvious once you open the hood. Mine is crammed with wires. :D
OBS96
Renton, Wa
It's a 96 F350 5SPD Manual
Sorry, I guess I should have stated that in the original post. Thanks Guys
