Get Free Denali Fishing Rod with UnderCover Offer at CARiD!
Level-up the usability and protection of your Ford truck with UnderCover FLEX Tonneau Cover and receive a FREE Gift at CARiD! Now until March 15th when purchase a FLEX cover, you can receive a Free Denali Fishing Rod. This cover is made using a fiberglass reinforced polymer that is lighter, stronger, and more dent resistant than a standard aluminum cover. It folds into three positions that lock into place, full coverage, ¾ bed access, and full bed access. Designed to hold up to 400 lbs of evenly distributed weight, it provides the best bed protection and improves gas mileage up to 10%.
Features:
- Ultra-low profile design, gloss black finish
- Full bed access - the cover folds up to the cab and secures with prop rods
- Integrated channels in the side rails guide water to the front and out of the truck bed to keep your cargo dry
- Can be easily removed in minutes without any tools - Scuff, dent, and UV resistant - Easy no-drill installation using E-Z style clamp system only takes around 10 minutes to install
- Water-tight seal helps protect cargo from the elements
- Custom made to fit your truck
- Backed by a 3 year warranty.
UnderCover™ | Tonneau Covers & Truck Bed Accessories - CARiD.com
UnderCover FLEX Tonneau Cover is one of the most reliable covers you can get for your Ford, that can give you an easy access to the truck bed and at the same time provide excellent cargo protection. Look no further – make your purchase today and take advantage of UnderCover Promo at CARiD!
