Give your Ford a modern twist with Tough Guard Exterior Products!
One of the cheapest and easiest ways to upgrade the look of your Ford truck is to install a set of side visors and a hood protector by Tough Guard. When it comes to stylish and functional products, Tough Guard is the name you can rely on. This brand offers FormFit Side Visors and Hood Protectors with aggressively styled “bolt-on” look of popular fender flares.
Both products are made from high impact ABS co-extruded with an acrylic top layer for a superior appearance and long-lasting service. Even if your truck doesn’t have fender flares, the Tough Guard will suit almost every truck. Another great feature is the ease of installation - it will take only 15 minutes to attach both products to your truck using the 3M automotive-grade adhesive (no drilling required).
Tough Guard® - Tape-On FormFit Side Visors
Features:
  • Made from high impact ABS co-extruded with an acrylic top layer for a superior appearance and durable finish
  • Complement your Tough FormFit Guard with matching Tough FormFit Visors
  • OEM Quality look and feel
  • Won't chalk, fade or breakdown over time
  • Allows you to drive with your window open while offering protection from the elements
  • Increased air circulation
  • Each application is precision-fit to your specific vehicle
  • No cutting or modifications required before installation
  • Installation time in under 15 minutes
  • Attaches via 3M Automotive Grade Adhesive
Tough Guard® - Black FormFit Hood Protectors
Features:
  • Durable ABS with acrylic top coat has an OEM quality look and feel
  • Matches OEM and aftermarket fender flares and other components
  • Installs with 3M Automotive tape, patented mounting clips and stainless steel fasteners
  • OEM quality design rests on the mounting hardware
  • No contact between the deflector and the hood - no risk of paint wear
View the full list of Tough Guards Products for your Ford https://www.carid.com/tough-guard/
Keep your Ford fresh, stylish, and protected with Tough Guard!​
