mspainting
Painting The Town
Ok i bought this truck last year & on the way home it broke a hpop hose, got it home, had more hpop leaks then blue the icp out replaced it runs good, then trans took a dump had it rebuilt, he had to change cpu, also every now & than have to ad oil to hpop because it won't start it is either bleading off or it is not picking oil fast enough, now i've got more codes & i looked them up & this what they said what i'm woundering is are they related or just happened at same time
P0472 Exhaust Back Pressure Sensor Circuit Low Input
P1670 EF Feedback Signal Not Detected
P1211 ICP Not Controllable - Pressure Abow/Below Desired
P1212 ICP Voltage Not at Expected Level
my signiture should have info about truck & what mods have been done
Thanks Michael
Thanks Michael
