guages
jocephus
campbell/mo
just ordered a set of glo shift guages and to get the best deal i had to go with a 3 guage set i got boost egt and oil temp i dont have a auto tranny so no need for trans temp i was wondering where to tap in to get engine oil temp. and is there a fitting i can take out to get boost pres instead of cutting the map tube and using a tee.
rammertide07
Rogersvilles, AL
I think on the 99+ trucks have a place around the "Y" pipe that you can plug the boost line in to. I just cut into the MAP line and put some wire ties and a hose clamp on it.
You need to fill out your signature so we know what exactly we are helping you with. Go to the user control pannel up top, then slect edit signature on the left
jocephus
campbell/mo
thanks im also wondering about how to get a R size drill bit no one seems to know what im asking for at the parts store.
rammertide07
Rogersvilles, AL
And if you talking about a bit for drilling the egt probe...some people started with a smaller bit and then stepped up one or two time. I just used a bullet bit that has a smaller tip to start the pilot hole and then goes up to the correct size
Kenbo11
