HD radio installation help
kbud14
I will never learn
Ohio
I bought a sony HD reciever for my Kenwood head unit that is HD ready. The reciever had 3 wires. A yellow 12 volt source, a black ground, and a blue wire, ANT REM. Max Supply current 0.1A. For some reason, I do not have that wire on my truck. Where can I hook that wire with a max current of 0.1A?
the blue wire is a "remote turn on" signal wire...when the radio turns on
the blue wire sends the signal to other devices, power antenna's, amps,
caps that they should turn on.
the blue wire is an OUTPUT signal wire...no voltage should be applied TO
that wire.
kbud14
I will never learn
Ohio
ok, well thats what i thought. I dont understand why it doesnt work. Everything is hooked up as should. I should be able to find HD RADIO when i push the source button, but it isnt there. Any ideas? I am sorry if i am vague.
kbud14
I will never learn
Ohio
I was told it was by best buy. I asked twice. He said yes. I called sony about it and they said NO its not compatable. I am a little upset.
jpringle83
WA
Here's what you need to do. Go on ebay and find the kenwood HD radio tuner it plugs in with a single din cable which provides power and the ability to directly control through your kenwood head unit. If you have any questions about this stuff give me a shout I was an installer for about six years and still do some side work.
