Help Needed help engine died
tommydawg
hemet calif
can any help me ,my 97 7.3 died last week I changed the fuel filter and cam sensor I pulled 2 fault codes p1211 and p1212 can anyone point me in the right direction Im pretty sure its a fuel deleverey problem I just cant pin point the problem. thanks :confused:
bbressler
Happy, TX
Those codes are related to the ICP, you don't happen to have the 10K mod, do you?? If you did, I'd try removing that and see if it's any better....or you may try replacing the ICP sensor.
bbressler
Happy, TX
Yup...
should be right behind the AC compressor.
Looking for a picture...
Paul H
Thronville, Ohio
Quick note.
The injectors need something above 500 psi to fire, If you have a bad ICP you can unplug it and try to start the engine. Seeing no ICP signal, the PCM will use a default setting of 750psi as a pass / fail pressure for the IPR.
It will throw a CEL but will start.
if it does not start, you may have an o-ring blown on the end of the IPR not allowing it to build injection pressure.
