Help no crank!
used to be that you could replace the starter mounted
solenoid separately (unbolt it & replace it)...last time i
went to do it (96 f150) the cost between it and the
lifetime starter from autozone made it cost prohibitive...
i figured i was under there...id just replace the entire starter.
autozone doesnt list the solenoid separately...
169 (after core charge) for the LIFETIME WARRANTY starter & solenoid
autozone.com
Good Info BP.. Thanks
Dogman
tampa,FL
for all the 7.3 PSD
A/C Delco #F917
There now you have the part number just incase. :D
When I get the starter cores back I test them and it's 95% of the time it's the solenoid thats bad. The rest of the starter is fine.
